Grohe Wirelss Service Codes
9 Nov 2003
Birmingham
Need help! Grohe Wireless shower is not working, coming up with Service Code 13. Does anyone have the service codes?
Thanks for your help.
Thanks Picasso. I have an unvented cylinder with boiler temp set to 70 degrees to heat said cylinder... ill check temp at hot outlets but is there any guidance given on how hot is too hot?
Is it possible to mail me a list of the codes.
Thanks again RGM
One of my Grohe wireless showers also displays Service 13 from time to time. The shower becomes scalding hot, then shuts off (for safety reasons, I imagine) displaying "Service 13". Restarting it after a wait, I can turn the temperature all the way down to "LO" yet still the shower is warm.
The thing is, I've noticed that this behaviour seems to coincide with electricity power cuts to the house. And I have discovered that the problem goes away if the mains to the shower is turned off for a minute or two, then back on again. So I suggest the OP tries that.
My theory is that short-duration power interruptions (brown-outs) cause some kind of corruption to the shower's memory. But longer power cuts (with clean power restoration events) allow the memory to be reset cleanly.
When it happens again I must ask Grohe what's going on...
Temperature
- Maximum (hot water inlet) 70 °C
- Recommended (for economy) 60 °C
