Hi All,
I know there have been a few threads on french drains etc but this is a slightly different question.
On paving expert he mentions the use of "fin drains" instead of geotextile wrapping round pipe and gravel approach for below ground drainage ( ie: not surface)
I have seen examples of this using ie: Terram Geotextile on the industrial infrastructure scale but not found anywhere that supplies it for domestic/ private use? Has anyone ever used this before?
The land drain i'm planning is 30m long so a drain 250mm wide and say 900mm high means something like 9-10 tonnes of gravel- @ £30 a tonne from my local quarry thats an expensive hole in the ground!!
Also they only supply washed limestone whhich apparrently is not the ideal choice of stone for ground drain/french drain.
Any thoguhts much appreciated.
Thanks.
Thanks.
