Ground floor DPM nightmare... what to do?!
21 Jan 2026
Part of our house is 1950s blockwork without DPC or proper DPM in the kitchen area.
After a botched job to put in a liquid DPM (so we can have laminate) this is what we've been left with from top down:
5. Top layer of Ardex NA. This layer has cracked in places (10 days after works were complete) - 2m cracks in some areas - localised mainly near edges (I suspect mainly over the areas where the sand cement bossing was filled badly).
4. Ardex liquid DPM - not enough was used (should have used 2x10kg tins for whole space and didn't) and judging from the box meter readings taken after (75-90%) this has failed. Meters were left for 72 hours - albeit the house isn't heated atm - but the room gets lots of air. Protimeter readings done by Ardex rep were 250-400. There are no burst pipes under the floor.
3. Layer of Ardex NA
2. Thinnish layer of sand cement (very, very brittle). Had large bossed areas which were filled in with something as yet unknown.
1. No idea of base - presume stones/gravel, not sure if there is a concrete slab, suspect not.
Question is
A) do we make them dig up and start again doing DPM properly, knowing that they could cause even more issues with the base sand cement layer below or B) risk it with a vapour barrier underlay taped over whole floor (like "quickstep basic") and put laminate on top? Or will this mean we get awful mould/damp walls....?
Can't put more DPM over top as current level is getting too high. And can't dig down to do proper meshed insulated floor as sheeting and joinery already done in the room, so wouldn't be able to get to external walls for DPC rendering it pointless.
Main query: Have you put down floating floors on concrete without DPCs before? Any problems? Or worries when doing it? Most grateful for any advice! Thank you ...from a very stressed contributor
Why not plastic sheet. That's a dpm.
Felt underlay for insulation.
Laminate flooring on that.
That's what I would of done. I'm no expert though on flooring
I've been told that a plastic sheet can actually cause more of a problem by trappin moisture rather than breathing... so hard ot know what to do and so frustrating that the guy didn't use the right amount of the DPM - we'd have never had had this problem!
It's a tricky one, the NA is all moisture tolerant and a very good screed when applied correctly. Likewise Laminate floated on a underlay with DPM and tape does have an element of moisture tolerance to it as well.
'by the book' would be to take up what you can, re-dpm, NA properly all at quite some considerable cost and time/mess/disruption.
How bad are these 'cracks' ?
Hi crazydaze - the cracks are very localised at either end of the room - about 2m long but only at points - I'm not so concerned about the cracks as they are obviously where they failed to fill the subfloor bossed parts properly so there's a little movement but it's under where the units are going on the whole. The cracks are not throughout or in the middle of the room. I'm more concerned about whether we have to re-do the DPM - thus causing more damage to the subfloor taking it up (which again will need repairing) or whether a good underlay will do. Has anyone ever just used underlay on a floor without DPM or DPC with success?
Wondering whether it's possible to take up just the top layer of the ardex sandwich and add more DPM C1 and then top layer Ardex NA again? Anyone ever done this?
They were put across the whole floor - no units in yet
The hairline cracks arent too much to worry about, but that screed blowing out like that would suggest very high moisture levels?
as in the sand cement? ....basically the plan now is to take it all up and somehow(???) stabilise the sand cement below and start again.....any advice so welcome for doing this as the guys really don't have a clue what they're doing and I can't seem to find anyone in the area who does...
