- Joined
- 5 Jan 2004
- Messages
- 7
- Reaction score
- 0
- Country
I have had an airlock on my pump so I opened the air bleed screw in the middle of the pump after sorting out the airlock by draining off some water from a rad water was dripping slowly from the pump bleed screw hole. I tighted it up , Ran the system and felt very pleased with myself ...........
Then the RCD tripped and sickening feeling hit my stomach.... oops.
I can run everything fine with the pump disconnected from the wiring panel . The boiler fires up and heats the water . Without the pump running I only let it run for a bit as you can hear the water starting to think about boiling !!.
The resisitance was about 200K ohms between L or N and Earth. With getting the pump body hot all day it seems to have gone up to Inf so I connected it back up. It still blows the RCD out. I measured the other way and appear to have a rectified loop.
I can't understand how the water got to the "electrical" side of the pump. I have not stripped the pump down yet and am not sure if they are "servicable" to that level but I suspect some arcing during the "wet" fault that has left a track for the rectified leakage current.
How is the pump constructed.
No water has got to any of the external fixtures on the pump it ran down the outer casing from the blled hole?????
HELP
HELP
