Hi there all fellow DIY'ers.
We have a Grundfos pump (not sure of model) And after our rainwater tanks ran dry (pump seemed to still work), we have noticed that the pump runs continually and finds it hard to get up the required pressure to turn off - but only sporadically.
We have bled the line, and this worked for about 24 hours, and have also installed a new rope filter. The tanks which we have just cleaned (lots of gum trees around) were FILTHY and had a sludgy sticky substance on the bottom, probably from the oils in the leaves of the trees.
My question is, does the pump require priming (is that the word - when you use a bicycle pump to achieve a pressurized bladder again) or would it require cleaning, or is it completely had it because of running dry?
Hubby has just noticed that there is a valve at the bottom of the pump as well as the top (where we bled it through), would this be where we'd clean the actual pumps internals?
We are in a rental property and are not overly familiar with tanks/pressure pumps.
Look forward to your response.
Thanks heaps.
Ann
Thanks heaps.
Ann
