My system is based around a Glowworm Ultimate 50ff some thirty years old. Over the years I have worked on it many times and always managed to solve problems, thus i have an extensive supply of parts. However after all this time finally the Grundfos pump gave up. I replaced it with a Grundfos UPS3 pump. This seems to be working OK. The boiler also starts up OK but after 5 minutes shuts down and stops power to the pump. Often the overheat is tripped. Wait a few minutes and the exercise can be repeated.
My thoughts are that there is no water circulation even though there is a new pump. My suspicion is that the two valves which I closed to replace the pump have not opened properly. The system is thirty years old and I am aware that the two valves to shut the water off are no longer available and there are rumours that some of them are problematic. Those supplied today are gate valves. I feel mine are the problem type as they operate as a regular tap, so there must be a washer. which after all this time ..........
I hate the prospect of draining the system but for me filling the system is always a major problem. Can anyone confirm my suspicions?
