I fairly recently renovated my central heating system.
However i have gurgling coming from 1 panel radiator being fed from 10mm microbore, and what i think is rather a lot of air being bled from 2 towel rads, and a long vertical column rad upstairs.
The boiler is upstairs and feeds the, upstairs rads first then drops 10mm microbore down to the radiators below.
each 10mm microbore is fed from 22mm flow and return pipes.
the connections into the rads are 10mm mb with reducing olives.
I also dont think i have balanced the system very well either, and this is a job on one of my list.
I dont think the system is producing hydrogen, as i have tried the lighter trick at the bleed valve.
I dont have any water leeks in the system that i am aware of. only a little bit of discoloration, (rusty color) around the radiator inserts.
I thought air might be getting sucked into they system so i squeezed some lsx leak sealer around the rad valves, and screw threads.
But the system still gurgles.
Any suggestions?
Cheers A.
Any suggestions?
Cheers A.
