Gutter Support no fascia boards?
19 May 2005
Sussex
Our roof is an old overhanging job without fascia boards: they're horizontal if you see what I mean? :?: Not sure what the proper name is... So there is no fascia board to screw a standard gutter support in to.
Instead the round gutter is supported by a metal bar: a horizontal bar screwed into the roof with a U-support at the end to hold the gutter.
Again, not sure what the name of this type of support is but I can't find any replacements anywhere! :x
Any suggestions much appreciated as a joint is sagging and I want to push it up a bit to stop it overflowing in heavy rain...
Cheers!
Edit: oh yeah, and I've only got the ladder till Tuesday!!! :lol:
Im also not sure what these are called, but everyone ive seen, including the ones on my house, are adjustable. the ones ive seen have a two bolt and thread setup, if its sagging id like to bet the Motar has crumbled around the bar... you might get away with fitting some kind of plastic wedge under the bar to lift it back into place...
top fix rafter bracket?
Its part of the gutter between two of the supports that's sagging - I was going to try and fit an extra one. I guess it depends if I can screw it in? If it need bolts I may be stuffed since I don't know what the access is like.
hmmm
