gyproc easi-fill - how deep can you fill?
19 Nov 2005
Bedfordshire
As above really - how deep can you sensibly fill before you need to prefill with plaster. Does easi-fill sand easy(compared with polyfiller). All you guys seem to use it in pref to polyfiller - Why? Thanks
You can fill to a depth of about 3/4mm....more than that and it will take an age to dry out.
It doesnt compare to polyfilla...its for large areas and joints in plaster board.
Polyfilla is for general porpous use ...you can be all means use it on big areas etc but think about the cost...1.5 kg of polyfilla is about £3.50...10kg of easi-fil...is about £10...its also far easier to sand
Polyfilla can be used on deep holes, gaps and cracks...easi fil cant..
Two different products really
