I have an open vented system which feeds a cylinder and boiler. When the boiler is operated the pump seems to operate but the hot water is also backing up the supply pipe from the boiler back to the F&E tank which is then pouring out the over flow pipe. The pump was changed recently, I have changed the stat on the cylinder. My next two steps would be to change the stat on the boiler (glow worm hideaway) or check if the cylinder is split inside. Is there an easy way to check this or could this be something else. Any help/advise is greatly appreciated.
Many thanks
Paul
Many thanks
Paul
