since 10 days of fitting it leaked brown water from inside the pvc, so water was getting under the grey top and above the pvc base cladding.
fitter has returned 5 times to attempt correction, excuses have been main roof leaking, ive just had main roof felted, then the over flow pipe above could have a leak and the water is in the cavity and some how coming out in to the flat roof.
water is brown so in contact with copper or a lot of rust.
After i have run around trying to work this out myself!! i start to loose patience the problem started 10 days after fitting doesnt take a genius to do the maths.
aparrently the problem was the flashing sealed under the resin top??
now i have no flashing, and an unsightly roof.
does anyone here actually have any knowledge of the cavity trays in this wall i know they are pointless bent up copper sheets above doorways with no end stops but not sure if that flashing was actually part of a large one in this gable cavity.
also does anyone forsee future problems by having that flashing removed ive been waiting all this time to have my house painted, going to take some extra tackling with that resin up the wall GGrrrr
thanks OJ
thanks OJ
