Half circle of glass on UPVC door
12 Jul 2008
Wiltshire
Hello,
Would anyone know if its possible to replace these 4 sections? Reason is that mine are clear and I want frosted glass in there instead.
you can buy frosted sticky back plastic or indeed you can chemicaly etch the glass :D
How do you go about that then, ive had a look and its sealed each side, no trims ect to remove like normal windows.
I've been keeping an eye on this post :D because last time i looked the unit is sandwiched in the door panel and can't be removed!
Thats if i'm thinking of a semi-circular bit of glass with 3 white georgian bars in?
