I have a Halstead Ace HIgh boiler which is providing intermittent hot water. When a a hot tap is open, the water gets very hot, then the boiler cuts out, then fires up again. Leaving the tap open for a while causes kettling, and the overheat to trip. The problem seems to be that the gas burner isn't being modulated on the DHW, but the CH side seems fine.
Any ideas what this could be? The corgi man is thinking the PCB, but I'm loathe to change that at £150 - £250 if it turns out to be something else.
Any suggestions would be greatly appreciated.
