Anyone know if there are replaceable seals to go around that little pin that pushes out from the group set upon dhw demand and turns on a burner switch
? I have droplets of water coming out and regularly shorting out the switch which strangely doesn't cause the boiler to fail but does cause the hot water light to come on and the burner -which is not good -presumably.
I have cranked surrounding nut tight and still leaks. If there are seals, what are they called and where could I buy them? Are they diverter shaft seals?
many thanks in advance.
