Halstead Qauttro does not fire up
25 Nov 2005
Halstead Qauttro does not fire up. few years ado it did the same thing,I rang Halstead technical help line the advised me to push down a red knop on the DH thermostat which I did. However, this red knop is sticking out and no matter what I do it done not go down. I believe this is what stopping the boiler to fire. can I by pass by connection the two wire going in to it for very short time to see if the boiler fires. the only part is working when there a demand for DHW or CH is the pump and the diverter valve.
sorry, it is the overhead thermostat not the DHW thermostat
called couple of local guys who spend 30 minutes each and they could not get the boiler going. do British gas do fix price repair? if so, what is their contact details. do halstead have specially trained engineers in every city like Worcester for example. any help would highly appreciated
If the red button doesnt push down it means it hasnt activated, if it has you would feel a click when you pushed it down, if the reset button is part of the Overheat thermostat then I think you have a quattro gold , on the quattro the reset is outside the boiler at the top left hand side
