The cheap TRVs I brought from Screwfix are driving me mad! I get hammering loud enough I'm surprised the neighbours haven't come around to complain about me using a jackhammer at all hours.
I've bled the air out fully, tried reducing the system pressure down to about 1bar when hot (as well as increasing to 2bar hot) and adjusted the locksheild valves on the knocking rads to reduce flow, but no luck.
The TRVs I have are supposed to flow both ways, and some are on the inlet others on the outlet but theres no commonality between the ones that knock or not.
I've come to the conclusion I need to replace the TRVs with some decent ones (Drayton TRV4's seem popular on here) but should I swap the valves around to they're all on Inlet side, or will replacing with decent TRVs alone cure my problem?
