as title does anyone have a good method of drilling hanging tiles seem to have a few unvented cylinders at the moment and a few of them have this issue
Drilling vertical hanging tiles in-situ can be a very tricky business indeed.
Because you are in essence drilling down on two fixed tiles its very easy to crack the under tile.
Remember that all vertical tiles are double/fully nailed - or should be.
There are all kinds of silicone glue on jobs - but thats well risky/irresponsible.
Bent copper tingles will work but still a risk.
Depending on how close you are to an upper abutment like a soffit or frame then it might be better to lift the tiles down from the abutment to the tile in question.
Then remove and drill it - but its a lot of work, & can go dire if you crack a tile with no spares available.
There was a tile Mfr. who sold specials precisely for pipes and fixings etc - but I dont recall who they were or if they are still out there.
