I have a hansgrohe shower pump fitted in the house I've recently moved into. Whilst the cold water pressure/flow is excellent, the hot water pressure is awful and sometimes gets so low that you'd think the pump was switched off. Its also very noisy too - I'm sure it should be as loud as it currently is.
However, I cant find anywhere that sells these pumps? Does anyone know of anywhere where you can buy them, or would a plumbers shop be able to overhaul it?
Also, what does positive head mean - that the cold water tank is above the pump?
