Hello,
My central heating system is fairly old and has been modified a few times. Right now I have a sealed, pressurised system with a single pump and two motorised valves controlling the hot water and central heating. The boiler is a traditional floor standing unit about 10 years old. It's not a combi.
The motorised valves were put in by British Gas last year replacing two pumps (one for each - CH and Water).
I am wondering if the system has been setup correctly as when the time clock turns both the heating and water off and closes the valves, boiling water is sitting in the boiler and pump runs for upto 40mins trying to move it - which of course it cant.
Should there be another pipe allowing a trickle, bypassing the valves, controlled by a tap to allow the boiler to cool down? If so, should this be plumbed into either of the feeds to the CH or HT after the valve?
Or, does this matter? Is it okay for the hot water to sit in the boiler and for the pump to run for 40 mins?
Thanks for any help you can offer.
