Alerted to a problem by the outside overflow from my H&E tank, I discovered that during a recent visit my plumber had deliberately raised the F&E to submerge the expansion pipe. The water in the tank was really hot when I inspected it.
The motive I think was to cure air getting into the system. The plumbers had just swapped in a new condensing boiler (open vent system) and there was constant gurgling and swishing that days of bleeding and head-scratching just wouldn't cure. The pump was set to its lowest speed but on stopping and starting you could still hear it overpumping (?) into the F&E so I suspect this was the inspiration for the "system modification".
Submerging the expansion pipe seems a bit non-standard to me, and I don't think it has cured the air getting into the system either. Having recently heard of fatalities through scalding water dropping down from attics I'm not sure if our system is even safe to run.
As for the air (?) in the system, the pipework is in the right order with the cold feed just under the pump inlet - and expansion just under that. The system was power flushed and filled with corrosion inhibitor and wasn't impossible to bleed before the new boiler was fitted. None of the new pipework appears to have leaks - hence everyone is clutching at straws (evidently).
