Hi
I've just installed a new door-stop composite door. Everything went fine until I realised that when you shut the door from the outside, you can simply pull the handle to open it again without using the key. The old UPVC door would shut and pulling the handle down from the outside wouldn't open the door. You had to use the key. Whereas the new door can be openned from the outside unless I remember to lock the door with the key every time I leave the house.
I compared the handle and spindle on the old and new door. The old door had two spindles going through it and neither spindle went all the way through to the opposite handle. The outside handle had a spindle that went into the lower part of the locking mechanism. Pulling up on the handle would engage the lock but pulling down wouldn't do anything hence why you couldn't get in without the key.
The new handles are Fab Fix and there is one spindle that pairs up the handles in the upper opening of the locking mechanism. It looks like I need the outside handle to have a fitting for the spindle slightly lower so the spindle goes into the lower part of the locking mechanism but I'm not sure what to search for online as all handles seem to be in pairs with one spindle.
Any help would be appreciated
