I am trying to change an old ceiling light fitting in my living room with a standared pendant fitting. Removed old fitting and there are 2 lots of cables coming from the ceiling. It is not clear which one is the switched live as it has no sleeving on it. Not a problem I thought, i will wire it up using one black as the switched live, the 2 reds to loop and the other black to 'N'. It did not work so I just swapped the wires over and thought it would be that simple. Its still not working.
Is it possible that if I wired it up the wrong way the first time that it could have broken the 2w dimmer switch?
i cant think of any other reason for it not working. All the other lights in the house are working.
Cheers
Cheers
