Heat Loss - Pen & Paper Check
I would try the opposite approach, leave the TRV heads fully open and properly balance the radiators
That was what I first tried, but some where I have a fault, I have found no by-pass valve, but with all TRVs closed hot water still returns to the boiler, so there must be one somewhere.
I will guess when garage converted into a flat, the valve was hidden behind some plaster board, but no idea where, so all lock shield valves left wide open, or radiators do not heat up.
This also means a mechanical TRV is useless, as the range of temperature to too great, so all are programmable electronic types.
So it is a bit of a lottery as to which room will heat first, unless TRV heads set in a sequence, and some times one room needs to get to temperature and the TRV heads close for that room, before another room starts heating up, but that is only a problem if I have discharged batteries in the TRV heads.
But the problems with my system are nothing to do with heat loss and sizing the boiler correctly, but it does show how central heating can work room by room, and also how important re-heat times are.
The commercial regulations allow one hour for rooms to get to temperature, and I consider this is a good rule of thumb, even if not legally required for domestic.
In the main, over night, rooms will not cool to below 16°C so looking at time to go from 16°C to 20°C even if we want 22°C by time 20°C is reached, the room is comfortable.
For a small box room, a 1 kW radiator can heat the room without a problem, but as the rooms get larger, my living room around 10 x 7 meters, even with two 2 kW radiators will take some time to heat.
The air needs time to circulate, and try and heat it too fast, will result in cold areas. And also the air needs to heat furniture.
As to weather compensation, yes I can see how in summer a room at 18°C is good, where in winter want the same room at maybe 22°C, but that's so easy to program session to session, how can any device work out if a human feels cold or not?
It doesn't, it only raises the temperature to whatever is set by the user. It you want to warmer then set it higher, and vice versa.
