Well must admit I did not read the post correctly ?? but none the less i wolud stick with a heat only boiler as opposed to a systems boiler , no water press switch on a heat only !!
Just gonna go with a heat only boiler I think. It's cheaper, less to go wrong, system works fine as it is, not a big job to change the wiring to the existing pump if needs be. I've got the option of floor standing or wall mounted in heat only aswell
My next question is the gas supply. It's currently 15mm and comes off the meter in lead. Should I have this upgraded to 22mm copper or 28mm? It's about 20 metres from the meter to the boiler
