The problem with those systems is that they dont have an amazing heat output. I think they are only around 50watts per metre. Also cost! They are seriously expensive.
The only ones Ive seen in the UK are the myson (seen in more commercial installations) and the heatprofile make. When I priced up the heatprofile stuff, it was going to cost around 3x that of a radiator installation.
If you need skirting heating to overcome draughts, then I would suggest two 15mm pipes at skirting level.
