I have some (quite a few) problems with my DHW/CH system.
The house is from 1979 and was 10 years ago extended.
When I bought the house last August I noted that a valve fitted next to the heater leaked over its stem. When I wanted to overhaul the valve and therefore disconnect it electrically I noted that it was not connected (only the blue wire was connected, brown was loose). Looking in the connection box it was a big mess electrically. I have tried to clean it up a bit, but will need to improve further. I had to make my own schematic as nothing made sense. At that time it was noted that the room thermostat was disconnected and further the timer looked so shabby that I decided to replace it.
Regretfully I can not follow the piping completely and therefore do not exactly know what kind of system it is. I looked on various sites and found some reference to schematics and concluded the system should be a "Fully pumped system with a 2-port valve for optional CH".
Most heaters have TCV's. Therefore I connected the valve in series with the wall stat. There is no Cylinder stat connected to the system. This has the system working, but then I noted further problems as follows:
1) The pump is noisy and vibrates and this seems to increase.
2) It is as if you can hear the water being pumped through the system. Sounds maybe odd, but it makes more noise than I’m used to.
3) One TCV starts to hammer when the set temp is reached.
I don't know if the above could be related or not. Any ideas?
Many thanks, Rene.
Many thanks, Rene.
