Heater works fine, no HW
31 Jan 2005
Help please; I have a Junkers Euroline Combi. As near as I can tell it is a sub of Bosch however, I can't find a Bosch model that is exactly like it, similar, but not exact. Anyway, central heat works fine but no HW. When I turn the HW on the unit won't start at all, I get luke warm water for a few seconds and then very cold afterwards. There are five LED lights that normally depict the tempature of the water but now the last one, which is normally 90 degrees, is flashing. Also there is another light that is flashing red that looks light it may indicate some kind of electrical fault. I am having trouble finding any kind of literature that isn't in Spanish, so if anyone has any advice, I would be greatly appreciative. I am tired of waiting on the spanish technician to decide if he has enough time to come out and take a look at it.
Smelly without a shower
Normalmente, ninguna agua caliente significa que hay un problema con una cosa que llaman " la válvula de desvío ". Pero esto no enciende las luces. Por lo tanto es más probable que usted tenga un problema con un sensor o el bordo de electrónica.
En este país usamos "Corgis", reparar cosas así.
¿Quizás usted les llama perros daneses?
Ellos son malolientes hasta con una ducha.
Los talentos ocultados ChrisR, me impresionaron casi pero no seguro ayuda al individuo con el problema.
Bahco - posso farlo in frog, wop, dago o kraut ugualmente se chiunque lo ha bisogno.
Dappertutto la stessa cosa accade, merda va verso il basso.
Gracias todos los personas pero, no hablo espanol. Por favor escribe en ingles. Gracias.
