Heating and water
11 Jun 2015
Durham
Hello
I have a ICOS HE18
System ,I recently had a leaking radiator ,which was changed ,then the boiler was serviced , shortly after this when you turn the water on to heat up the heating also comes on .
And ideas on what's wrong or if it needs reprogramming ,or a faulty board
Regards Paul
It'll be a problem with your system rather than your boiler. There will most likely be a three-port valve that needs changing
The zone valve may have been latched in the manual position and left there after the system was refilled. Try turning the heating on for a minute and then off again and see if that fixes your problem. If not, as suggested it may require some work on your valve.
I tried the control panel, when you press the radiator switch ,it does not fire the boiler ,but the boiler fires when you press the hot water switch but both the radiators and water come on ,I've also noticed the water is not very hot now .
Would this still be the valve ? And would you know how much this work should cost me ,thank you
Regards Paul
