There name tells you why they are required, Pressure Relieve Valve, whether they are needed is immaterial, they were fitted because they were a manufacturers requirement.
If you want to read the book you'll have to let me know.![]()
Your old one is leaking purely through age
DIA has given the best answers on why they where req.
All gas boilers in the past required them then it changed to boilers with low water content heat exchangers then to not required at all and dropped out of manufacturers instructions as a requirement.
On standard domestic systems them come in 1/2" and 3/4" in correct position the easiest way to change them was to snatch them ,we still laugh at our mate who took 1/2 one out threw it behind him only to find the 3/4 one in his hand would not fit![]()
And use a black iron plug to seal it off better than a brass plug
Go on doetail you tell him, you do not use a black iron plug if it were a direct system.![]()
Good old doetail you have the last word,whether it be right or wrong. Now that`s what I call, fighting spirit.
