We have 2 Glow-worm 30si boilers in our home, controlled by a Horstmann Centaur Plus C21.
Recently, one of the boilers has started displaying "F1". From this forum, I understand this means "Ignition Fault" or "No gas/flame detected". Is the correct?
The other boiler is running fine
Another issue (I am not totally sure if this is actually an issue), is that the control unit doesn't seem to be turning the boilers on and off. We have set various on/off times for the heating and Hot water, but it seems that even when both systems are supposed to be off, the boiler is still running. We can even switch both systems to "off" on the control unit, and still, the boiler doesn't turn off.
The system is part of a Pressurised "Megaflo" system, with a Horstmann HRT2 Thermostat if that is of any relevance.
