I've recently moved into a old property that has two sources for heating and three for hot water. The previous owner had a terrible system set up with two separate honeywell controls (timers) - one just to switch the oil fired boiler on and off, the other seemingly just operating the valves and pump(s). There's an additional proprietary controller for the solar thermal and I'm not 100% certain what that is doing other than controlling the pump for that closed circuit.
This system is a nightmare, the Worcester Bosch boiler randomly comes on even when there is no call for either heating or hot water and needs to be manually overridden. Only one of the two controls has battery backup and in the event of a power cut they end up out of sync. For whatever reason it also seems to want to fire the boiler even when the back boilers (wood fired stoves) are in operation.
I've fitted heating controls before in my previous houses, and thought I had a pretty good understanding of the architecture but these were much simpler single boiler systems. Can anyone recommend any heating controls that can manage multi-source systems such as this efficiently? I'm not really sure what I'm looking for and while I've found systems such as the Vaillant sensoComfort, it repeatedly mentions working with Vaillant Solar Thermal, Vaillant Boilers etc giving the impression it may _only_ work with their own products.
I may still ultimately get a pro in to connect it up, but I really want to know what I'm getting and not end up with a plumber recommending something that's simply unsuitable.
