Hi. I'm trying to plan out the heating for my next house. There will be a wood boiler heating a thermal store which will feed some underfloor heating and a couple of zones of radiators. My plan is that there will be a mixing valve getting water to the right temperature for the three circuits of ufh. I can't quite get my head round the controls. I was hoping that a programmer would turn on the rads and ufh in the morning and evening. I assume the rads should have trvs and a bypass valve for if the pump turns when the valves are shut but what about the ufh? Should there be a bypass there or if room thermostats tell the actuators to close does it tell the pump to stop turning as well? Hows a simple system usually set up?
