Hi all,
I had some basic thermostats fitted to my heating system last year, with 2 zones upstairs and downstairs the basic system features a "manual return" in the hot press see the picture below.
The basic problem is that the zone exclusion valves never close completely, even when the thermostat closes the valve the water pressure from the pump opens it again (they are spring loaded valves).
This problem is worse downstairs than upstairs, closer to the water pump I guess. I can actually hear the valve creaking open and closed under the water pressure when its supposed to be closed
I have a set of (relatively) new valves to be fitted and these are rated to a much higher bar. I am just nervous that when they go in they somehow break my pump as my heating zones have never really been "closed" before (the pump has always pushed them open). What are the chances?
Ray Kinsella
Ray Kinsella
