- Joined
- 13 Sep 2011
- Messages
- 68
- Reaction score
- 0
- Country
We've moved into a house recently and the heating bills are crippling us.
Last week we had some work done by a plumber as some of the rads weren't getting very hot and the heating was costing us a fortune to run. Our first bill was £170 for the month (Nov 18 - Dec 19) and then £110 (for Dec 20 - Jan 16) when we went colder and only had it on for four hours a day.
He powerflushed the system (although by his own admission nowhere near as much came out as he was expecting, very little in fact), fitted a new thermostat away from the cold outside wall, fitted one of those devices that collects sludge etc. and you can empty out by hand, increased the size of two radiators and rebalanced the system.
Since this the house has got a little warmer, the hallway rads now warm up and our bedroom is warmer, but the small bedroom is always freezing (despite the rad being warm) and one of the two radiators in the living room doesn't get very warm.
The main issue though is the cost. This evening it took 3.5 hours to get the house up from 12 degrees when I got in to 17 degrees, which is what the thermostat is set at. During this time, it took approx 60kwh of gas to do so. Hot water was on for half an hour during this time as well.
Our boiler is a 70kw Potterton, non-condensing. I think it's about 8-10 years old. We have 22mm pipework (and the plumber thought it should be 28mm for that size boiler, but said that it would cost a lot to replace all of the pipework and may not be an expense we want to incur).
We have 12 radiators, all double, and one towel rail. He calculated that they added up to 40,000 btu, if that sounds about accurate. We have a mix of 600x500 and 400x400 sizes mainly, depending on rooms, and he checked that they were all the right size (which is odd a the little room about 8 feet by 6 feet, but with half of the room reduced head height due to a dorma ceiling as it's a side extension, with a 300x300 rad).
I'm not sure if 70kw is too much and that is causing a problem (I've never even heard of 70kw boilers before to be honest, it sounds like a lot) and whether if we went for a lower kw boiler whether that may even improve things.
The house, as far as we are aware, doesn't have cavity wall insulation (it's a 1930's semi) and has only one layer of loft insulation. So that's obviously an issue, but not, I don't think, by any means the only one. And we're doing the loft in about four weeks to 270mm insulation and looking at having cavity wall insulation (although the horror stories I've heard with older houses and cavity wall insulation are frightening me). We have double glazing. Not very modern (early 90's) but still double glazing.
Any advice greatly appreciate as at £4.50 for each weekday heating and about £7 for each weekend day heating it's costing us a fortune, and is something we just can't afford long term.
