Is it more efficicent to keep heating on all day as apposed to switching on and off? Causing peaking. Any one done research on this subject?
You are using the fuel all the time the house is heated. You are just fueling the heat loss of the building! For an older semi thats about 10 kW !
So for each hour that you dont heat it you are saving 10 kWH ! Thats about 90p depending on your tariff and boiler efficiency.
Its always cheaper to ONLY heat the building when its occupied!
It seems very difficult to get some people to understand this!
Tony
