Hi
Recently moved into a new house and although the heating works fine (if a little cold on some of the radiators) there is no hot water at all.
The boiler is a Glowworm economy plus with an immersion water tank.
When I set it to water only mode the boiler fires up for about 30 seconds then goes off, it then repeats this until i switch it off but no hot water. When set to heating and water mode the boiler works fine and the heating comes on but there in no hot water.
However, in both cases, there is a loud clanking noise coming from the immersion water tank. I took off the metallic cover to the immersion and it seems that the noise is coming from the thermostatic rod (i disconnected this and took it out and it stopped the noise).
Any advise greatly appreciated!!
