Hi just after some advice
The elderly lady next door has had her bath room re tiled . The guy who did it removed the rad to tile behind it . he did not drain the system just closed the valves and removed it . After the tiling was done he put it back refilled the rad via the boiler .
The guy who refitted the rad has buggerd off and left this poor woman in the **** !
The problem is that now that two rads at the front of the house dont heat up . these are at the front of the living room and in the hall . they are on there own drops from the ceiling .
The system is run from a combi boiler , the hot water is fine and the rest of the rads seem to be heating up ok .
The boiler is getting up to temp then cutting out quite a lot
The boiler is a vaillant turbo may 824
Right here is what i've tryed to sort the problem
1. turned off all the working rads and ran the system.
nothing
2. turned off all the working rads and bleed a load of water out .
and nothing .
3. i also opened the filling loup a little bit and drained more water out of the rads
4 ive blead all the rads to . ive drained out about a 2 washing up bowls of water from each rad then refilling back up to about 1.5 bar
im thinking that there is an air lock or a blockage in the system .
nothing
and nothing .
