Hi all.
Had the floor up for something else and spotted something on the plumbing for the central heating that I thought I would query. (only had the house 3 months)
There are 22mm supply and return lines run out under the floor from the boiler to the middle of the 1st floor landing with
one of these (link) manifolds on for the first floor radiators (5 rads) and two tees to take the 22mm headers down to below the ground floor.
One of the supply 8mm take-offs from the 1st floor manifold just ties directly back into the return manifold.
This to me seems to be a bit daft and would just 'short circuit' the system? I thought about minimum flow line however there is a gate valve at the boiler between supply and returns, and also the ground floor bathroom rad is lockshields only (all the rest are TRV).
I am an operator offshore so do a lot of pipefitting however I dont have the experience on domestic stuff to say if there is a good reason for this.
Any advice would be grand whether or not this is correct.
Also, all the radiators are run on 8mm microbore with runs to and from the manifolds of about 5-8 metres from the supply/return headers. Although everything seems to get hot alright is this okay long term or is it going to be better to think about repiping in 15mm when I decorate?
Cheers all.
R.
[/url]
Cheers all.
R.
[/url]
