Hi all,
I posted a while back but cant find post. Basically i asked for heating suggestions.
Anyway i would like if someone can run over my calcs and my choice of heating system i think im going to purchase.
To start this is a industrial unit.
Its is 32meters long
9 meters wide
Approx 8 meters high.
no windows but has two steel doors and a roller shutter that is around 8 sq'm in size. The roof is a pitched roof with no void but 75mm insulation (steel roof) Also the walls are brick but top half is insulated steel also. Im a middle unit so have someone either side of me (the 32meter long walls)
It also has a mez floor in one half but is open fronted.
I can only have a oil fired boiler.
im looking at buying -
1x 5000Kw Radiator (storage area that is stud wall)
3x Heater blowers 18kw each (water feed)
1x Worcester Greenstar Utility 70kw HE oil Boiler
Does the above combo sound like a good option and will the boiler and water/heater blows heat the place? am i over sized or undersized?
Many thanks
9 meters wide
Many thanks
