Hi all
My house has a Baxi Solo WM RS conventional boiler dating back to about 1990. In terms of controls, there is an external SwitchMaster 400 mechanical controller, which probably dating back to the original boiler install. The controls are very crude and allow for water or heat/water only - no independant heating or program options. The controller is wired to an ACL room thermostat, which is also ancient looking. In the airing cupboard we have a 'Grundfos Selectric' pump and a Drayton 3 port mid position MA-1 valve. The tank has a Danfoss thermostat attached.
Everything works as it stands, but I am looking at the options to bring the system into the 21st century. The boiler is working, so this can stay put. I've checked with Baxi and the boiler just needs a switched mains fed live (240v) so the guy suggested the controller upgrade is an easy route given the mid-position valve already in place. I'd like a modern programmable timer and stat with independent heat/water control. Not really very clued up on the better systems and don't mind whether wired/wireless. So I'd appreciate any advice or recommendations on the upgrade path.
I can provide pics on any aspect of the system if it would help.
Thanks in advance.
Thanks in advance.
