Heating system - water usage
3 Jan 2011
Norfolk
I had a leak in system last year, repaired OK. However, since then, on tying-up the float valve, I notice it does drop slightly, measured about 50mm over 18 weeks. Is this to be expected? Any advice appreciated, thank you.
HERTSDRAINAGE2010, thankyou for reply. I have little experience of heating systems, but can I presume that if there are no detectable leaks, the water use should be almost nothing? I don't have any reason, but I would have thought that some water gets used, undetectable leaks, evaporation, etc. Before repairing leak last year, the header tank was emptying in a day!
