Heating system with 10mm microbore
6 Feb 2010
Blackpool
On a heating system with 10mm microbore on drops down the wall does it it matter that on on so some of the up stairs rads.espically they have a much shorter run of 10mm pipe so basicall straight of 15mm with just a bit of 10mm. Just may need balancing?
Thanks as long as balanced.should be ok? Do they say the manifold system were there at a central point with 10mm micro bore coming of is self balancing ie wont need doing
