Heating tape to prevent frozen pipes
6 Oct 2011
Staffordshire
Hi all,
After suffering two burst pipes last winter because my bathroom extension doesn't have a room to keep the water pipes warm, I have decided to fit the thermostaically controlled water pipe heating tape.
Does anyone have experience with this, and how difficult is it to fit?
Any advice welcome :)
I think you might be referring to trace heating, which is used to help prevent condensate freezing.
Since you are in Staffs, pop on round to FSW, they have it on the roll that can be cut, terminated and flex connected to. It can be a bit of a fiddle to fit neatly but it should help sort your problem. I always use self limiting tape which never gets too hot should it cross itself.
Don't forget that your installation should always comply with the regs, earth bonding, RCDs and all that.... Especially since it will be in a wet area
Raychem have been one of the market leaders with trace heating and laterly with PTC resistors and cable.
Its relatively expensive though.
If yoiu have a small amount of electrical knowledge you can make trace heating yourself from standard wire and a low voltage output transformer for about £5-£10.
Tony
The tape is very easy to fit, just take you time when forming it along the pipes.
You use a special tape to fix it onto the pipes, similar to a fabric tape but stronger. You could use an alternative tape as long as it is strong, wouldn't think pvc tape would do, something like duck tape may do the job. As a temporary measure to ensure the tape stays snug to the pipe you could ty-rap it, or use string or similar, once you fit the tape remove the temporary ties.
The tape does not have to be wrapped around the pipes as can be seen in a few images on the web.
Use self limiting tape as is will limit the max temperature of the tape.
Different ratings of tape are available, e.g. 10watts per foot / 10watts per metre etc.
Can also be found with the name "parallel heating cable"
One end is terminated with an end termination kit, which basically ensures that the two wires do not touch anything, including each other.
The other end, as has previously been mentioned, could be terminated onto a flexible wire, then onto a 13a plug. Not directly into 13a plug.
As you mention, you are going to use temperature switch, which is fine, but you could also consider a simple segment timer. A 24hr timer with the segments set to perhaps come on for a 15min period every hour during the night, this could be adjusted depending on how cold it is, with the setting adjustable to suit conditions.
The 13a plug is only an option, for your situation you may want something more permanent. (fixed)
Of course you are going to lag the pipes once the installation is complete :)
The tape can sometimes be found/used in the chemical industry, just in case you know someone in that type of job, they may be able to assist :wink:
