Hi all,
hope you can help me.
Ive got a biasi riva compact M96 24 sm c2
hot water is fine.
when I put the heating on, it stays on constantly, the rads get
too hot to touch. the boiler goes off and I have to re-set it.
I had an engineer out. He replaced the heating sensor. He said he also
set the boilers minimum and maximum gas pressure. (whatever
that is)
I messed a bit, and when the hot water is on I turned the hot water
knob up and down, and the flame moved up and down. This also happened when the heating is on. Is this right ?
Even when i turn the heating knob to the lowest setting, the flame
is constant, untill it gets too hot and turns itself off.
I called another engineer who said it could be a pcb or safety stat.
All means nothing to me, just would like to be armed with some info
so I dont get ripped off again.
Thanks in advance for any advice.
hot water is fine.
that is)
