Heatstore HSX18N Problem
26 Jan 2010
Kent
I have a Heatstore HSX18N, found unit not working one morning and thought the Thermostat/cut-out needed replacing (did not realise they could be reset).
After installing Thermostat/cutout it lasted about two days and then operated the cut-out again, this has happened three times now. does anyone have an idea on this as I've only had it for 18 months.
The unit is also run off of a permanent live so is manually switched on and off.
