I have a small radiator in the hallway, 19 inches wide it is situated between the bathroom door architrave and the boxed in pipes which runs from ceiling to floor, but i got the architrave replaced to a wider one and now the pipe which fits onto the left radiator valve will not sit tight to the wall to screw onto the valve, if i replace the radiator to a smaller one, can the copper pipe be cut and re soldered to suit the new size radiator if the central heating system is totally drained,
i know it would be a lot easier to cut a check out of the new architrave to accommodate the pipe but i don't want this as it would look crap.
