Help and Ideas on boiler flue options
18 Oct 2006
Norwich
Hi everyone
I have a floor mounted gas boiler in my very well ventilated (brrrr) kitchen. The flue from the boiler goes up and out of the chimney stack (lined).
We're currently working on plans for an extension to the kitchen and I'd like to move away from having to have the kitchen very well ventilated to outside.
Is it possible to convert to balanced flue and still use the chimney...or is it a new boiler time in a new position?
Any help much appreciated.
The best you might be able to do is to place the external ventilation immediately behind the boiler so that there are no cross drafts in the kitchen.
However the improvement in efficiency from a nice new condensing boiler would lop about 35% off your gas bill.
Wow this is all very interesting - thank you very much.
I reckon we will end up creating a new utility room that would seem sensible to install the boiler in there.....I'm keen to avoid a combi as my bro is having trouble with losing pressure on the one he had installed.
Hopefully I can get a wall hung boiler and with vertical flue...and take it up through the ceiling..into the eaves of my chalet and then out through the roof tiles.
Shame I can't re-use the current boiler it's only 2-3 years old apparently
Open flued boilers require ventilation.
You CANNOT connect a balanced flue to a chimney
you will need to replace the boiler for a balanced flue room sealed model and disregard the chimney.[/i]
Careful here, he may have a leak in the system somewhere, which would cause
problems on an open vented system, though he wouldn't notice it. A well installed sealed system is a positive thing. I agree you should avoid a combi if you can find room for a domestic hot water cylinder, if you already have one of these beasts you must make sure it states BS1566 on the side or you will have to get a new one when you renew and move the boiler.
Should be able to.
I am surprised the ventilation bothers you, knowing what I know I would be delighted to see that ventilation, it is your friend. Trust me.
.No
There was a post a few days ago about this and apparently there is a boiler with a balanced flue suitable for chimneys!
The main idea behind it, was for replacing BBUs,
Can't find the post so no further details.
Whatever happened to Gasmanuk?
Some models have a lot of flue options, if you have difficulties.
A word of warning from an installer, if you have to call out Keston service engineers (which you will trust me) then make sure the customer dosnt miss the appointment, mine did & Keston kindly sent me a bill for £82-25 call out charge, so i sent them an invoice for the several in warrenty visits i made to repair there crappy boilers.
Up until about a year ago Keston boilers wernt to bad, but recently i have has a lot of problems with faulty ignition & very noisy burners, i will not be installing any more despite the flexibe flue system.
PS. if your reading this Keston then start looking after the installers, no installers = no Keston
Rant over!!!!!
All b*ollox, you need to convert to a room sealed condensing boiler, simple as that guy cost normally 2,200 rubies :wink: (pounds)
