Help boiler electrics
2 Feb 2008
Liverpool
I have a Biasi 24s boiler and because of a leak which has been fixed the 3a wall fuse keeps blowing. The part that seems to be causing it has on it
Cogema 948016 rr 2x2 5mh-2.5a
it has two blue wires and two brown wires and a round brown plastic piece in the middle of the wires with a copper coil inside. one blue and one brown go into timer switch box and the same into the wire connection box. The guy that fixed the leak and was good enough to come out on a Sat afternoon said let them dry out first but that he thought that this part had blown because of the smell and take it to a local spares shop on Monday. I would like to know what it is as it looks very easy to fit. Apparently there is also a blow fuse 16t which I have but I do not know where it goes. Does anyone know.
Thank you
Fed up and very cold
SOunds like a Suppressor - a part which it could do without until you can get one. Do try a hairdryer on it though (with power off!)
