Hi i have a rehema avanta 12v boiler which is playing up since the header tank in my loft was moved. the system was drained and re-filled and bled and seemed ok for a couple of days then started playing up
Whatever i try to bleed or look at all looks ok the 2 way valve is diverting water the right way, the pump is running but the boiler will only run for about 1 min after firing up then shut down wait about 5 mins then try again and do the same. This is the same on water or heating or both
Any suggestions greatly received
