I live in a mid terraced house (2nd from end) made from concrete , ive lived here just over a year and havet done any major work (changed back door from wood to pvc, blocked up an external door and put a window in, taken a window out and removed lower wall and replaced with french doors, changed 3 bedroom ceilings and had a new central heating system fitted). At 1st i started getting small cracks in upstairs ceilings and just thought it was because i'd been in the loft (old hose and im not the lightest person) but im not getting cracks around the skirting boards up stairs and on down stairs ceilings, what could be causing it?
Ive not taken any internal walls down although 2 have been removed, the walls that have been removed run parallel with the floor joists so assume they wasn't supporting walls (im no expert tho).
Thanks for any help
Thanks for any help
